1998 z28, all forged 383, 9". custom paint... more
Year: 1998
Make: Chevrolet
Model: Camaro
Price: $9000
Mileage: 112000
Private or Dealer Listing: Private Listing
Location (State): OK
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
I am asking 11K OBO. Not really looking for trades. I am purchasing a CTS after this sale.
Maul flattop pistons
Eagle forged crank
Eagle h-beam rods
TSP stage 2.5 5.3l heads re tapped for std temp sensor and an steam crossover (2.04 int, 1.60ex).
Ported oil pump
Electric Meziere waterpump
Double roller timing set (adjustable).
ARP head studs
Comp Cams 228/234 cam, comp cam pushrods and LS7 lifters.
Typhoon intake with 96mm TB
82lb injectors
Converted to 2000 up computer. Running EFI live COS 3, SD.
TSP 1 7/8 stainless Headers with stainless (off road) y-pipe.
Adjustable Borola exhaust.
9” rear with 3:55 (Mouser I believe)
Built 4L60E with Vig 2800 to 3000 converter
B&M shifter
AEM WB
New ZR1 polished wheels and tires.
Chromalloy driveshaft.
255 in tank pump
Aluminum Radiator with new Hi flow Flex Lit Fan kit. (relocated forward radiator.
New AC system.
New water pump with Truck alternator conversion.
12AN crankcase evac system with stainless catch can.
Custom paint and hood.
I ran low to mid 11's motor refresh.
Car handles and drives great. Very tight.
Great leather on inside.
Now for the bad.
Fuel gauge does not read accurately… sender maybe?
Very slight seeping from 9” rear end… maybe member gasket? Not enough for me to do anything about.
No cruise control
And surprise, both door motors are slow.
price update, 9500.00. May consider trade for clean Wrangler for my sone to drive.
I do not even have the time these days to fix the window motors, so I understand the little things may be running off potential buyers.
Back up. My wife showed me a plastic pee soaked tester this morning with a red line across the little viewing indicator. yep number 3. This just compounds things. I am excited, but concerned. I will be 60 when this one gets out of HS.
Car is got to go and I was just ready to keep it. The water pump started leaking last weekend, so I put a polished electric Meziere one on it. Heater blows hot now... must have been the t-stat causing the low heat issue.
no CTS or jeep foe me now.
