Lifters - Comp Pro Mag vs LS7
What's the advantages/disadvantages to each (LS7 vs Comp 875-16 Pro Magnum lifters)? I have a brand new set of Comp Pro Mags that I was given, however I'm trying to decide if I should use them or go with LS7 lifters. I will be using the factory non-adjustable rockers and doing something like a TR Torquer 3 cam and PRC dual springs. 7000RPM max.
For a factory lifter they are decent but they leave a lot to be desired.
Bump! I'm a believer in doing it once and doing it right and I'm in the hunt for lifters. litle88 I like those lifters you showed, I assume they will fit in LS2 lifter trays? Anyone else have any preference on lifters if they wont go with LS7's????
