Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Rear differential?
Old 03-12-2013, 10:02 AM
Bow Tie Power's Avatar
Default Rear differential?
Hey guys. First of all, I apologize if this is the wrong section; I'm new here. Anyway, I just bought a 1997 Camaro Z28 30th Anniversary Edition with no motor. The seller told me it has 4.10 gears in the rear differential I was just wondering if it's possible to actually determine that, and if so, How?
Old 03-13-2013, 10:42 AM
97camaroguy's Avatar
Take off the rear cover and count the teeth.
Old 03-13-2013, 12:57 PM
CamaroAJ's Avatar
or even easier one revolution of the axles will be 4.1 turns of the pinion.
Old 03-13-2013, 01:43 PM
ss performance's Avatar
What he said. Mark the tire with a strip of tape and the pinion with chaulk. Slowly rotate the tire (or brake) for one revelution while counting the pinion rotations. It might be easier if you have a friend to help.
Good Luck
Old 03-22-2013, 07:28 AM
shepss217's Avatar
yup, the pinion should make a little more than 4 rotations compared to the tire
Quick Reply: Rear differential?
