Ls2 engine swap won't start
Please help.
I installed 05 gto ls2 into my 1967 Camaro convertible. I used the gm performance wiring kit with there computer. I had a local machine shop change the 24 tooth reluctor wheel to a 58 tooth. I also changed the crank and cam sensors to grey sensors. Just found out that the upper timing gear was different so I changed it from a 1x to a 4x gear. I can not get it to run. I have good fuel pressure and spark. It seems as if the timing is off. I am getting worried that the machine shop put the reluctor wheel on wrong. Any ideas or thoughts would be greatly appreciated.
