2002 Camaro SS 1LE Very Low Miles!!! Garage Queen
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $22000
Mileage: 8500
Private or Dealer Listing: Private Listing
Location (State): OR
Color: White
Transmission: Manual
Drivetrain: Rear Wheel Drive
This car is bone stock right down to the original airlid and filter. The only mod is a plug-in SLP skip-shift eliminator. Only 8,500 miles on the odometer!!! 100% garage-kept
Car is a 6-speed 1LE Hardtop in Arctic White with the black leather interior.
SLP number 348
Specs:
1LE package (Double adjustable Konis, stiffer springs, stiffer upper & lower control arm bushings, hollow 32mm front sway bar w/ revised endlinks, reinforced body mount brackets and firmer bushings, aluminum rear lower control arms with stiffer bushings, 21mm rear swaybar & bushings, koni stock adjustment tool).
Hardtop (NOT a t-top)
6-speed
Auburn Torsen rear differential
Factory Traction Control Delete
Car may be 1 of 1 with this specific color/option combo (unknown since SLP won’t release specific build records)
Car has SLP Birth Certificate.
If you want a showroom stock SCCA race-car this is for you!
Original owner, factory ordered through GM (owner is a GM dealer but this was his personal car).
GM Build Info (Does not include SLP assemblies):
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
10Q - ARCTIC WHITE BODY SIDE MOLDING 10U - ARCTIC WHITE
192 - INT EBONY 19I - EBONY INTERIOR TRIM
1SD - OPTION PACKAGE 04 1SZ - PREFERRED EQUIPMENT SAVINGS
6BS - FRONT SPRING 7BS - FRONT SPRING
8TJ - REAR SPRING 9TJ - REAR SPRING
A31 - POWER WINDOWS W/ DRIVER'S SIDE EXPRESS DOWN A90 - POWER HATCH RELEASE
AG1 - SIX-WAY POWER DRIVER SEAT AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS
AR9 - CLOTH BUCKET SEATS AU0 - KEYLESS REMOTE ENTRY W/ ILLUMINATED INTERIOR FEATURE W/THEFT DETERRENT ALARM SYS
AU3 - POWER DOOR LOCK SYSTEM WITH DELAYED ACCESSORY BUSS B84 - BODY SIDE MOLDINGS
BBS - HURST SHORT THROW SHIFTER C49 - ELECTRIC REAR WINDOW DEFOGGER
C60 - AIR CONDITIONING CAE - UPFITTER CONVERSION - Z28
DG7 - ELEC TWIN REMOTE SPORT MIRRORS DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE4 - RIDE & HANDLING SUSPENSION SYSTEM FE9 - 50-STATE LOW EMISSION VEHICLE
G80 - LIMITED SLIP DIFFERENTIAL GU6 - 3.42 RATIO REAR AXLE
IP2 - TRIM INTERIOR DESIGN - AR9 J65 - POWER DISC FRONT & REAR BRAKES
K34 - CRUISE CONTROL-ELECTRONIC K43 - GENERATOR 102 AMP
LS1 - ENG 5.7 LITER SFI V8 ENGINE MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION N73 - CUSTOM SPORT WHEEL
NF7 - FEDERAL EMISSION SYSTEM NLEV NP5 - LEATHER WRAPPED STEERING WHEEL
PBT - ID TEMPORARY HOOD, PROC OPTION QFK - P275/40 ZR-17 S/B RADIAL B/W
SLM - STOCK ORDERS STE - ST THERESE, GM OF CANADA PLANT CODE
T82 - TWILIGHT SENTINEL HEADLAMPS T96 - FOG LAMPS
TS9 - HIGH LEVEL STOP LAMP - DELETE U73 - FIXED MAST ANTENNA
UA6 - THEFT DETERRENT ALARM SYSTEM UB3 - GAGE PACKAGE WITH TACHOMETER
UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS UN0 - AM/FM STEREO RADIO WITH SEEK-SCAN,DIGITAL CLOCK, AUTO- TONE CONTROL, CD PLAYER, THEFTLOCK, AND SPEED COMPENSATED VOLUME (BASE RADIO)
UZ7 - MONSOON PREMIUM SOUND SYSTEM WITH 8 SPEAKERS AND AUXILIARY AMPLIFIER (BASE SYSTEM Z28 & UPLEVEL ON BASE COUPE) V12 - POWER STEERING COOLING SYSTEM
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA VK3 - FRONT LICENSE PLATE MOUNT
VM3 - CONSUMER INFORMATION LABEL WU8 - "SS" PERFORMANCE/APPEARANCE PKG INCLUDES: *325 HORSEPOWER *FORCED AIR INDUCTION HOOD *17" ALUMINUM WHEELS *SS SPECIFIC REAR SPOILER *HI PERF. RIDE & HANDLING SUSP. *LOW RESTRICTION DUAL OUTLET EXHAUST SYSTEM *SS BADGING
Y2Y - SALES PACKAGE CAMARO SS DUAL Z28 - CAMARO Z28
[IMG] [/IMG]
i cant believe what im seeing, i just sold the same car a little over a year ago. i really mean the same car; the color, int, ext, stick, 1le, no mods, and same mileage haha. i was selling it for my mom. from what i remember there was a little over 100 for 02 that had the 1le package and the artic white was the least common color for that year too. i know hers was ordered the last week you were able to order before they were discountinued. slp should be able to give you the build number if you have the vin, thats how i got mine and hers. i wanted to do the same thing and buy it but as you can tell by mine, i wouldnt of been able to keep it stock. GLWS
edit: just seen yours in a hardtop, the one i had was ttops.
Yeah we have the SLP birth certificate. Where did you find how many 1LEs were built? I asked Hamburger and he said they don't have the breakdowns of numbers at SLP (I guess they are in paper files and never got put into the computers before they stopped building them or something)?
My blk, A4, leather, dual/dual, 1LE, 10 spoke chrome wheels, 4,700 miles early on driving to and from Destin, FL. The only change I've made is the OE tires are now Michelin PS2s and the difference is night and day! Still have the original Goodyears.
