Out with Prokit.... In with BMR/Koni..
Old 03-23-2013, 06:27 PM
bayer-z28's Avatar
Thumbs up Out with Prokit.... In with BMR/Koni..
I love working on this car... it's soo damn easy.. I took my time w this and it felt like it flew.
Not bad I do say. The ride is dead level. I'm really impressed with the stance. And within a mile of the test drive I noticed a difference! It's not a harsh ride anymore! I doesn't slam or bottom out. It just rolls with the irregularities in the road. Got new rubber up front too. Point this car in a direction now and it WANTS to go there instead of fighting it and worrying about the back end breaking loose.
MUCH better! Weather is getting nicer so I'm gonna take it for a ride tmrw. I noticed too that the BMR springs didn't have to be compressed as much to get them into position on the shocks. The ProKit needed to be cranked way down before they loosened up on the old shock.
Anyway.. on to the pics..
Backs. Had the HH mod and the isolator to try and level it out. No avail. No HH and just the isolator in the back now.
My trick for getting the MC off. Loosen the ABS unit.
Fronts
My Strano Sway is rusting ... (Got both)
New 555Ex fronts.
Sorry for the bad pics. My 4s randomly takes amazing pics. And half of these weren't amazing..
Old 03-23-2013, 07:23 PM
Zlow28's Avatar
Stance looks great! Where your previous shocks billsteins?
Old 03-23-2013, 07:50 PM
98z8uup's Avatar
looks nice
Old 03-23-2013, 08:19 PM
bayer-z28's Avatar
Yeah. I couldn't salvage one of the fronts. Didn't try very hard tho. My strut mounts on the front are rusting tho. They're gonna have to get replaced eventually. Was gonna do it this time, but just been penny pinching. Loaded em up with Silicone spray this time to hopefully curb the rust.
And my rear tires look narrow as hell in that last pic. Even for 285s. They're 10.5"s. I gotta burn em off this summer and put some 305's on there. Maybe see if I can fit some 315's.
Old 03-23-2013, 08:47 PM
Snake_Skinner's Avatar
Beautiful Stance!!! Curious how'd it'd look with some custom vt rear isolators in instead of the stock rear isolators though.
Old 03-23-2013, 09:06 PM
bayer-z28's Avatar
May end up looking too low in the rear again.
Old 03-23-2013, 09:09 PM
JD_AMG's Avatar
About time! And told ya so....
Now get rid of the poly rear LCAs.
Old 03-23-2013, 09:13 PM
silverWS.6's Avatar
You have 285's in the back and 315's in the front? How do they Konis feel compared to the Bilsteins?
Old 03-23-2013, 09:44 PM
TheSilverOne's Avatar
the massachusetts roads can be painful, your body will thank you
Old 03-23-2013, 10:40 PM
garygnu's Avatar
I used a torq bit and a ratchet to remove the bolt under the master cylinder.
Old 03-24-2013, 07:59 AM
bayer-z28's Avatar
YES!! I was gonna sell the eibach/bilsteins for $250 shipped and get some UMI double roto LCA's.. but I had to cut one of the front shocks due to rust. Which sucked because they were still good. Oh well. I have one front shock now and two rears if someone wants the two backs.
285's in the front and 285's in the rear. 10 front 10.5 rear. The way it sat before would have rubbed if I went wider. I can probably go 305's in the back now. The bilsteins were a bit bouncy. Compression damping was ok, but the overall ride w the Eibach's was harsh.
CT roads weren't bad. And yes, the MA roads suck. I think I still need an alignment. Needs tie rod ends and probably ball joints... Not to mention new A-arms and Roto-joints. There's still a little bit of a wander at center. That's what my main problem was with the front end.
I still need axles and get the rear rebuilt. This thing needs gears BAD! Getting tired of the stock 3.42's. Been putting that off for a long long time.
Old 03-24-2013, 08:18 AM
LPE 403's Avatar
Very nice. Been fighting the Koni and new spring switch - have Bilsteins and Pros too. Kind of kickin myself I didn't do it when it was all apart. Seems a little high in front....285s helping that?
Old 03-24-2013, 08:33 AM
Coppertone's Avatar
Do you have long tubes? How's the ground clearance?
Old 03-24-2013, 09:08 AM
bayer-z28's Avatar
^ Yeah. I actually have a early set of SLP LT's. "Tuned length headers" Those are the kind that people avoid because of the ground clearance and the suspicion that they don't make the greatest power. I didn't have a problem with them with the prokit, but you just get used to which entrances and/or speed bumps you can drive over. My clearance is low, but it works fine.
I didn't notice a difference with the height difference w the tires. Had 275's before, but Nittos can run narrow, so I got 285's and they fit fine. Haven't had an issue yet w rubbing. Sidewall is about the same height. Can't tell if it's any different. Same 35 sidewall as before.
Old 03-24-2013, 09:26 AM
The Scammer Hammer
dr_whigham's Avatar
PM me about the rears man. I'm a piece-meal kinda guy
Old 03-24-2013, 01:41 PM
bayer-z28's Avatar
^ Will do.
Fresh pics. Had to wash the wheels off to see if it helped the stains/pitting. If you know of anything, check my thread in the wheel section.
Old 03-24-2013, 07:01 PM
Coppertone's Avatar
That ground clearance doesn't look so bad. I bought the BMR/Koni combo and just went with the stock springs (lower perch up front and hose mod out back) for fear of low ground clearance.
Old 03-24-2013, 07:12 PM
bayer-z28's Avatar
^ Yeah, it's really not that bad. I've got some of the "worst" clearance headers and I don't have a problem. And I was about 1/2" lower before this too. Maybe even 3/4" lower. But I've been lowered since 2006, so you get used to it pretty quick.
Old 03-24-2013, 07:24 PM
autogeek23's Avatar
LS1Tech 10 Year
nice! i bought the BMR springs and will be installing them soon. not sure which shock i will go with. Koni's must be worth it. a lot of ppl say to skip getting bilsteins.
cant wait to install mine. my car rides like a boat. stock springs and stock front shocks 171k miles. its gonna be night and day.
Old 03-24-2013, 08:38 PM
Latch's Avatar
Looks good... which exhaust tips are those?
Quick Reply: Out with Prokit.... In with BMR/Koni..
