01' Camaro z28 Hardtop 10sec car for $9,000!
Year: 2001
Make: Chevrolet
Model: Camaro
Price: $9000
Mileage: 115900
Private or Dealer Listing: Private Listing
Location (State): TX
Color: White
Transmission: Manual
Drivetrain: Rear Wheel Drive
Car is in San Antonio, Texas, but can drive to deliver car at reasonable distance or meet half way.
Cars I'd consider trading for would be as follow...
-Grand National
-1st, 2nd 70-73, or 3rd 87-92 gen Camaro/GTA
-67-72 Chevy pickup SWB
-Nova
-68-72 Chevelle
-06-09 TB SS plus cash on my end.
Engine Mods:
SLP air lid
Aftermarket maf housings (Blk plastic) unknown brand
Smooth bellow
EPS Custom grind camshaft (3/2013)
GM LS7 Lifters (3/2013)
GM LS2 lifter trays (3/2013)
ARP Head bolt kit (3/2013)
Comp Cams .675 dual valve springs
TSP 7.425 pushrods
Comp Cams titanium retainers & valve locks
GM MLS head gaskets (3/2013)
GM crank bolt (3/2013)
New valve cover gaskets (3/2013)
New waterpump gaskets (3/2013)
New front seal (3/2013)
New GM steel exhaust gaskets (3/2013)
New MSD spark plug wires (3/2013)
New NGK TR55's (3/2013)
GM timing chain cover gasket (3/2013)
Powerbond underdrive pulley
F.A.S.T. 90mm intake (Painted blk)
Nick Williams 90mm TB
125hp nitrous dry kit with bottle and bracket mounted in rear
Ractronix 255gph race fuel pump with hot wire kit
Prothane Blk motor mounts
Poly Trans mount
Exhaust:
Pacesetter ceramic coated LT's
TSP 3 inch Y
Dynomax bullet dumped over the rear axle
New Stainless steel exhaust clamps from headers to Y (3/2013)
Suspension:
UMI tubular lca's (red)
UMI tubular panhard bar (red)
Hotchkis strut tower brace (Polished)
Custom diamond shaped subframe connectors (welded)
AirLift dual drag bags located in rear springs
SLP line lock
Powerslot crossdrilled and slotted rotors on all 4 corners
Trans:
trans shifts like a champ!
centerforce dual friction clutch
billet steel flywheel
all new hydraulics,throwout bearing,slave cylinder, pilot bearing (1/2013)
Rearend:
10 bolt has been refreshed
28 spline Moser axles
AAM alunimun diff cover
yukon 4.10's
new krush bearing and complete rebuild
Appearance:
30% 3m window film
SLP Bowtie grille
SLP LT1 style SS fiberglass decklid spoiler
6000k hid low beam headlight kit
6000k hid fog light kit
Clear park lamp lens
1969 Camaro z/28 emblems
Wheels/tires:
American Racing Torque Thrust wheels
17x9 fronts & 17x11 rears
New front tires 275/40/17
still good drag radials out back Toyo Proxes TQ 315/35/17
Misc info:
Valve covers & timing chain cover are powdercoated mirror red
coil pack brackets are powdercoated ceramic silver finish
Has stealth box with new Kicker sub, Jenson cd/dvd/mp3/ipod deck
MTX 1000 watt amp
I have new dirverside door window motor, needs to be installed.
Car is a HARDTOP.
I recently went to Houston to look at a car I was thinking about trading with and had a lifter start making noise as I got into town. I had the car towed to GForce in Pearland and they found two lifters were the issue. They scoured the cam I had in it, so I re-ordered the same EPS cam and upgraded the lifters and trays. Car has all new gaskets, seals, plugs and wires. All installed by GForce Motorsports.
Car needs a windshield, and has a small crack in the driver door paint from previous owner.
Car dyno'd 440hp, 405tq to the wheels, roughly 500hp, 450tq to the flywheel. Car rarely sees the dragstrip but has gone 11.4 @119 with a 1.55 60ft on motor with the EPS FAST 90/90 setup. Tune was done by Kurt and PatrickG in Victoria, Tx.
Call or text at 956-251-6700 Steven or email @ fbodytexas at hotmail dot com
You can see a video of how the car sounds here:
Complete walk around video here:
I have a 1987 Buick Grand National. Bored .40 over, Precision 65/67 turbo, FMIC, Translator, Wide Band O2, 6 point cage, etc... Let me know either way. And I am located just south of Houston.
Some interior shots a few guys had asked for. In photos it shows with the white leather, but will come with the stock ebony clothe seats with no tears.
pic of stealth sub
back area
pic of deck and dash area, btw the red button is the SLP line lock
passenger door panel
driverside door, bezel around handle will be replaced before sale.
pic of stealth sub
back area
car
still available ?? Please email allm info so I can forward to my finance guy. Im at work till 16th.
Jerrycolwart@yahoo.com
