weird problem
Old 03-30-2013, 01:11 PM
Mr Phil's Avatar
Default weird problem
Every time my radio shorts out I lose door panel control, no windows no unlock only lock.... if I try to unlock it the car does a really fast ding ding ding ding ding.... While I'm driving the radio randomly shuts off for a few seconds then turns back on, annoying but no big deal, now however the radio is staying off and now I can roll down windowsor anything. I've checked all the fuses and everything is still good.... Any ideas?
Old 03-30-2013, 01:41 PM
Mr Phil's Avatar
I found this online but I checked power and there are no irregularities
http://www.justanswer.com/pontiac/2b...arily-cut.html
Old 03-30-2013, 02:52 PM
LunarWillow's Avatar
It's the solder joints in the BCM that's causing your issues. They just need to be resoldered, it's a common problem and an easy fix, I had to do the same on my T/A. Here's the thread you need, I'm not sure if the photos will show up anymore, but if they don't I know there's some floating around on here:
https://ls1tech.com/forums/general-m...blems-fix.html
Old 03-30-2013, 04:41 PM
Mr Phil's Avatar
Awesome Thank you, ill have to try to tackle this tomorrow since it started raining
Old 03-30-2013, 05:08 PM
You bet. It's simple as pie to fix, so you'll be good in no time.
Old 04-01-2013, 03:55 PM
Mr Phil's Avatar
Problem fixed, I cut a couple corners for removing the bcm but oh well it works now, and I also got rid of that damn door chime that never shuts up lol
Quick Reply: weird problem
