t56 problems
t56 problems
I have a 2000 formula 6spd. Im having some troubles with getting the car into reverse, let me re word that it feels like it goes into reverse fine but grinds when I start to let the pedal out. I just replaced the clutch with a ram hdx kit and a gm slave cylinder. Also had the flywheel resurfaced and new pilot bearing I was hoping that would fix the issue. I was sure to bleed the master cylinder out real good pedal pressure feels great just no reverse. PLEASE help im sick of making sure I can pull straight out of a parking spot or having to push my damn car back lol. Thanks guys
It,s not getting fully into reverse. It could be a combo of: bent fork, broken/ missing pads, worn clutching teeth on the slider and/ or gear. You will need a teardown to fix this.
BTW, its unlikely your clutch probs had anything to do with this and thats also why addressing that did not fix this.
