Could my t56 not be shimmed correctly??
My shifter rattles and shakes really hard when I get to higher rpm. This is after a rebuild but I never had the car before so I don't know if it shook before the rebuild. Anyways I changed the tranny mount with no luck. Could it be because I didn't shim it? If not what else could it be? Driveshaft? Tourque arm?
Does it do it in every gear? If so, usually rpm dependent vibrations are caused by something in front of the transmission......like an imbalance in the rotating assembly, front accessories or the clutch stack. Could also be a misalignment of the trans input to the centerline of the crank (maybe a missing alignment dowel?)
