Pushrod length tool
Old 04-07-2013, 01:26 PM
transbird95's Avatar
Default Pushrod length tool
When using a pushrod length checker do you need to buy the plastic rocker arms? Or can you just use the rocker arm you plan to use on the build? Just wondering as I was about to order a length checker and saw the rocker arms sold seperate. Thanks.
Old 04-07-2013, 01:57 PM
RamAir95TA's Avatar
I've always used the intended rocker arms.
Old 04-07-2013, 01:59 PM
ok, just wanted to be sure before I order. Thanks!
Old 04-07-2013, 02:10 PM
defaultexistence's Avatar
Intended rockers and a modified To be solid ls6 stock lifter here.. = great pattern on valve tip once proper length was achieved .
Quick Reply: Pushrod length tool
