Leaking hose??
Leaking hose??
Does anyone know what hose this is? The boot in the picture is over the tie rod on the left front wheel. The hose has got a leak, anyone know how difficult it is to replace? I would imagine the hose has to do with the power steering, because i just had to replace the fluid.
Save the manuals!
Trace the hose. If it has the same rubber-to-metal connector on the end that hooks up to the pump, its the pressure hose. EVERY parts store sells them for your car.
So, its easy to get. Its a PITA to replace. It will make a mess and you will get Power Steering Fluid all over the place your first time. There's no drain for the fluid, so its all going to come out when you disconnect the hose.
I'd suggest getting an original Helm factory service manual or even one of the Haynes manuals to help you through it your first time. Other than making a mess, its pretty much just turning a wrench:
- Disconnect hose from rack and drain
- Disconnect hose from pump (You may have to remove the PS Pulley and belts to do this. If so, you will need a special pulley remover.)
- Be sure that your new hose has rubber washers properly installed on the ends and hook it up.
- Fill with PS fluid and bleed the system. (I like to put the car up on stands and turn the wheels side to side.)
- Add fluid until the air is bled out and the reservoir is no longer foamy.
BTW - Its going to make a mess.
Save the manuals!
If you really want to get in to working on the car, the official GM Factory Service Manuals (they come in a 3 volume set for this car) can be purchased through the printer, Helm, Inc.: http://www.helminc.com/helm/welcome_...asp?Style=helm
You may be able to find these used on eBay for less money. There were some great deals when all the dealerships were closing but they still pop up from time to time.
If you go for a manual available in a local parts store, it will help with common things like you are doing now, but they don't cover every possible repair like the factory ones do.
It's not mine! woo hoo!
It's really a rather straight-forward job. Just have a drip pan or a bunch of cardboard and towels under the car to catch all of the fluid that runs out.
The most "difficult" part is getting the hose from the reservoir. I was able to get the nut loose with a wrench. Some people just cut the hose so they can get a socket over it. It's very easy to get it off the rack. Just spray some brakleen on it to clean all the grime and stuff.
