BMR front shock spacer review
I got them, because my pro kit sagged in the front...even worse because of my iron block. the front end was so low, i couldn't adjust it enough to correct the negative camber. the tie rod angle was so bad, it would force the car to dive more during turns.
They are advertized to raise the front of the car 1/2 inch, when in fact, it's closer to 1 inch, causing the front to sit about 1/2 higher than the rear with the hose mod.
Longer bolts should also be included (3.5"), due to either having not enough threads left or NO threads left when the spacers are installed.
Luckily, i have an ample bolt bin, and i still had my factory rubber rear spring perches to reinstall. So i simply reversed the hose mod in the rear, and the car sits level again.
It sits 1" higher in the front and 1/2" higher in the rear. Fixing the front sag also restored the proper geometry to the car.
BEFORE:
AFTER: front spacers and deleted rear hose mod
BEFORE:
LS1Tech Premium Sponsor
Did you give the car anytime to settle back down after you did the install? I am just curious to what the actual ride height measurement is after the spacers were installed. I will shoot my boss over the recommendation to include longer bolts with the kit which will definitely help make the install easier. We definitely appreciate your feedback!
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
i drove it around the block and weaved back and forth a few times to make sure everything settled back the way it was.
it sits at 26" from ground to fender with the iron block. give or take 1/4" from worn out strut bushings.
Okay let me check that measurement versus what we have and I will get back to you.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
