What is this thing on the t-stat?
Old 04-07-2013, 07:54 PM
HIZPANICGUY21's Avatar
Default What is this thing on the t-stat?
Just installed a new radiator so I figured I'd replace the t-stat and the radiator cap as well. When I opened the box the t-stat was in I heard a no use when I shook the box. I noticed the t-stat had a metal piece on the top that I'd never seem before. Is this normal or did I get a defected one? Here are the photos
Old 04-07-2013, 08:12 PM
obie86's Avatar
Its normal. I've seen that on every t-stat I've changed. Not sure of the function though.
Old 04-07-2013, 08:40 PM
It's not mine! woo hoo!
demonspeed's Avatar
That little brass thing that jiggles around? Totally normal.
Old 04-07-2013, 09:52 PM
LilJayV10's Avatar
LS1Tech 10 Year
It keeps from getting an air lock in the engine after you replace the thermostat.
It's basically a bleed hole. As you fill the radiator up, the air from inside the block is allowed to escape(forced out) letting coolant in. Back in the day guys would drill a small hole in the thermostat.
Quick Reply: What is this thing on the t-stat?
