Stall install
The only gasket I replaced was the pan gasket because I changed my filter while I was at it. Some recommend changing an O-ring, I think it's where the converter neck plugs into, but I didn't because I didn't find out about it until after my converter was already changed.
Take a look at some of the other TC install threads that have been posted
https://ls1tech.com/forums/showthrea...verter+install
I didn't replace any gaskets or seals when I did mine. I checked everything out and it looked ok. So I moved on.
good luck!
good luck!
