FAST rails.. no lines with kit what to use???
got the 146032 kit and it comes with not all the things i need to hook it up WTF FAST!! (about as annoying as the 102 without gaskets included)!!! Anyway i needed to know where i can find the cross over fuel line, fuel line fitting to the stock line up to the rail and the block off for the end of the rail. Do i need any type of regulator? i am assuming the racetronics is regulated in the tank and should be fine. thanks!
Here is all the fittings you'd need.
-6an hose end fitting for the feedline
http://www.jegs.com/i/JEGS-Performan...rentProductId=
-8an cap for the end of the fuel rails
(2 of these) -8an 90* hose end fittings for the crossover
-6an 90* hose end fitting for the feed line to the rails
Quick disconnect for hardline to AN conversion
http://www.jegs.com/i/Russell/799/644123/10002/-1
Do some searching online for the -6an and -8an hose. You will need probably 18" of both to be on the safe side. I will check to see if I have any left that I could make a deal on.
i see all of these kits but the aeromotive and the professional products is the only one i have seen with the male end to go into the stock fuel line.. or am i crazy?
well iwent to hook it up today and this fitting http://www.jegs.com/i/Russell/799/644123/10002/-1 doesnt work with what i have...
http://www.jegs.com/i/JEGS-Performan...03120/10002/-1
is what i need but with a 90 degree elbow on it any ideas?? i cant seem to find one!
You sure your hooking it up correctly? The little U-shaped part goes over the stock metal feed line first underneath the little bulge portion of the hardline. Then you put the rest of the fitting over the stock metal hardline and slide it til its butted up to the bulge on the metal feed line and then you screw in the U-shaped portion into the fitting until it is tight.
After that you have your 6an hose fitting that connects to the Russel adapter fitting.
Take a picture with what your working with if I am misunderstanding what your trying to do.
