1985 6.0 turbo truck
Old 04-17-2013, 07:21 PM
shaved87's Avatar
Default 1985 6.0 turbo truck
in the process of building my 6.0 for boost/nitrous figured you guys could follow and enjoy the build 1985 6.0 turbo truck-wastegate-during-hotside-build.jpg
I think im gonna come across the front with the crossover.... I know it doesnt look as good but i really needed that extra room for the planned 5" downpipe
Old 04-17-2013, 07:23 PM
shaved87's Avatar
Old 04-17-2013, 07:24 PM
shaved87's Avatar
btw the truck is a 1985 swb chevy c10 lowered with caltracs on the back and trick springs up front.... Pix coming soon Ill post bunch of pix because this build is going fast and im already a week behind
Old 04-17-2013, 07:39 PM
Twin turbo c5's Avatar
Turbo setup looks good. That should be a fun ride.
Old 04-17-2013, 07:42 PM
shaved87's Avatar
Question
its definately different Im gonna really need you guys input on how it should work with the nitrous and tuning also. I gave myself a 1000 hp goal. what do you guys think?????
Old 04-17-2013, 07:46 PM
427zm's Avatar
Give us some pics of the truck! Also, more detail on the setup would be nice. Is it a JY motor? Did you go through it? If so, what was done? Turbo size? A/R? Tranny? Truck use? Etc.
LS5.3stang's Avatar
Talking
looking good , looks like u got the center section of the turbo upside down, either that or thats the biggest oil feed i have ever seen.
Old 04-17-2013, 07:51 PM
LS5.3stang's Avatar
what size is that s400?
Old 04-17-2013, 08:26 PM
shaved87's Avatar
the motor has recently been rebuilt with all new bearings, polished crank, custom grind crower cam, ls6 oil pump, double roller timing chain, ported polished 317 heads pro flo xt ported to match the heads. i was running a 6an stainless steel braided for fuel pushing one inline 255. I now plan on going with the aeromotive 1000 with 10 an hose. the motor is a fresh rebuild to answer your ?? I just now want to put all this turbo/nitrous stuff together and make a bad azz combo
Old 04-17-2013, 08:27 PM
shaved87's Avatar
the turbo is a s400sx4 75 mm with 1.32 ar
Old 04-17-2013, 08:28 PM
shaved87's Avatar
lol ls 5.3 stang yes that is the return turned upside down mustve done it on accident we're still mocking up
Old 04-17-2013, 08:31 PM
shaved87's Avatar
I want to use the truck as a grudge racer and the trans is a th400 with a 2800-3200 stall with cheeetah shifter. I want this truck to be as mean and fast as possible been watching and admiring flaco build for sometime (Only if I had that type of money)!!
Old 04-17-2013, 08:33 PM
shaved87's Avatar
here are a few pics of the hotside that has been welded i used a bunch of ubend and j bends from summit mandrel bent 2.5" steel piping1985 6.0 turbo truck-hotside-ground.jpg
Old 04-17-2013, 08:38 PM
LS5.3stang's Avatar
that hotside looks good. how much nitrous?. i dont think u will have a problem hitting your mark with both power adders
Old 04-17-2013, 08:40 PM
shaved87's Avatar
well i kinda just wanted to use the nitrous to launch the truck and compensate for turbo lag. Its gotta nos cheater solenoid so theyre good to around a 350 shot but im really hoping i wont need that much, not wanting to detonate on me!!
right now i have the hotside welded up with a obx 60mm wastegate,the s400sx4 turbo, procharger big red bov, and a a/w setup with a froxen boost intercooler ,5" downpipe dumped just past the firewall. may even turn that intake around backwards and mount the intercooler under the dash .... that should look pretty good i think
I also need you guys help at helping me build a pretty stout shortblock ( i have to get rid of those stock rods and pistons) please include part numbers so that i can order the parts btw
Old 04-17-2013, 08:59 PM
427zm's Avatar
Nice this is going to be a fun ride. If you've been watching Flaco are you in Tejas? Any truck that can run 200 at the mile is serious!
Old 04-17-2013, 09:01 PM
shaved87's Avatar
no im actually in georgia maybe i shouldve specified " ive been watching a bunch of flaco videos " lmao
Old 04-17-2013, 09:03 PM
BMF_Racing's Avatar
Question
Looking good so far. Few questions that comes to mind. When you said the engine was rebuilt, do you know if it was just rings and bearings or was the rods and pistons upgraded also? One more question, do you know what year the engine is? What are the specs on the cam?
Old 04-17-2013, 09:08 PM
shaved87's Avatar
the rods and pistons were not changed thus i wanted to bore to 370 forged with hbeam rods. I do not have the specs on the cam as of now but i am sure that i would need a new one the lsa on the one that i have in it now are to small
Old 04-17-2013, 09:09 PM
BMF_Racing's Avatar
Just saw your 9:40 post about the short block... I'd go with Wiseco pistons and a good set of forged i-beam rods.
Quick Reply: 1985 6.0 turbo truck
