24X 1336 SES Code - Crank Relearn
I helping a friend finish up his 24X conversion and the tuner needs to do a Crank Relearn on the PCM to get the crank to match up to the injectors.
HP Tuners will not say "Ready to Relearn"... On LS1 cars is requires a specific coolant temp, the hand brake to be set, and above a certain rpm.. I'm pretty sure he did not tie the emergency brake into the ls1 pcm wiring. The car starts and runs, the coolant temp works, but no E-Brake signal.
Does anyone know how to get a 24X LT1 to perform a Crank Relearn, with HP Tuners?
Are you scanning while trying to do this? I'm pretty sure you have to be " connected" but not scanning. I'm fairly sure I ran into this problem as well with my 24x swap
