Any difference between auto and manual radiators?
I need to replace my radiator and was looking into the spectra cu1485 as I hear that is the thicker core rad without any of the LT1 crap on it, but someone mentioned it has a trans cooler built in which I won't be using since I have a 6 speed ie waste of space. Do all fbody rads come with the trans cooler built in or should I look elsewhere? If so, who can give me a suggestion on a good non stock drop in.
Thank you for the advice. I plan to only run about 550 wheel on an fi stock bottom ls1 so I assume I should be ok with an LT1 rad. I was concerned with the ports to plug but I'm sure it wont be an issue.
