Pontiac GTO 2004-2006 The Modern Goat
low speed fan replacement
Old 05-04-2013, 01:50 AM
Revelation Z28's Avatar
Default low speed fan replacement
my low speed fan motor is out and my high speed on the drivers side is the only one kicking on at 235, i changed the relays and still no juice. is there a replacement motor/singular fan? or do i have toreplace the whole thing? i wanted to see if i could rebuild the motor in mine first before replacing the whole assembly.
Old 05-04-2013, 11:33 PM
i "semi" fixed it but found the cause.
the "fan #2" 30A fuse had a broken ground terminal prong so when the pcm/bcm "grounds out" the fan circuit to kick them on low or high it wasnt a complete ground circuit. i need to replace that prong in the fuse box, im going to upload pictures of what i did to test it. basically when doing the jumper trick i connected the 30A fuse to 2 wires and touched the terminals. leaving relay #2 and 3 in and jumping the relay 1 terminals along with my fuse trick kicked both on low. jumping all 3 with the fuse trick made both kick on high.
below the black wire goes to the broken ground tab/prong where the 30a rad fan 2 f/l fuse goes.
Old 09-17-2013, 12:01 AM
Chevyman5436's Avatar
I've been having the same issue with the low speed not coming on, I'll have to give this a try!
Quick Reply: low speed fan replacement
