91+meth 5.3, turbo suggestions needed
I'm in the process of piecing together a turbo and motor setup for my T/A and wanted some input. The goal is ~750rwhp using an iron 5.3 I have in the garage. I didn't want to run E85 just because there aren't very many stations around me with it. Instead I decided to run pump gas & meth. I have been looking @ a Precision Billet CEA 7675. I want to stay with a T4 flange for weight purposes. Any suggestions?
-Setup
'03 L33 shortblock
LS9 Gaskets
Stock 243's w/ Lunati Dual springs, hardened pushrods & ARP studs
Speed Inc TU1 cam .581/.581, Duration @.050 is 225/225 113LSA
Alky Control Single Nozzle
80lb Injectors
Dual in tank Walbro 255's
-8 Feed / -6 Return
-Setup
'03 L33 shortblock
LS9 Gaskets
80lb Injectors
-8 Feed / -6 Return
