? hp i can get out of turbonetics hurrican tc78 96ar
Old 05-16-2013, 10:46 PM
s10pro's Avatar
Wink ? hp i can get out of turbonetics hurrican tc78 96ar
My build is a 5.3 with pat g custom turbo can kartech rod bolt and ARP head bolts Vic Jr efi intake 80lb in fuel system level 4 4l60 with yank 3200 .Turbo is rated for 750 HP but will it really be able to support that on a v8 with my cubes ? I wanted to try and push it to 600 to tire if possibl I am not sure if it just looks small being a hurricane series but can make the # is any one on running a hurricane on there setup
Old 05-17-2013, 03:55 AM
Johnv's Avatar
I made 700 rwhp on a 383 with one, best I've seen on the boards is around 800 rwhp.
600 on your combo won't be a problem.
Old 05-17-2013, 09:22 AM
Tally TransAm's Avatar
my tc76 .96 ar is about outta gas on the exhaust side. makes 610/670 on 14#s on a cam/317heads/347ci
a 5.3 should be able to get some more outta it
Old 05-17-2013, 11:37 AM
chiaj144's Avatar
There is a guy on this form that has a 6.0 mustang that has ran a 9.0. That's making some power.
https://ls1tech.com/forums/forced-in...-150-tc78.html
Old 05-17-2013, 06:51 PM
Blackpanther99's Avatar
You wont have any problems seeing that power. I assume you will be running pump gas right?
Quick Reply: ? hp i can get out of turbonetics hurrican tc78 96ar
