Car won't idle with BR7EF's?
I sprayed my car for the first time today and wanted to get some input on the tune and why my car doesn't want to idle. I have cam, bolt on car and I just put on a HSW plate kit with a 100 shot. I've got the nano 3000 kit to regulate bottle pressure at 1050psi and I'm using a timing tuner to pull 6 degrees while spraying. I installed BR7EF's and gapped them to .032. On my first pass, I was using a .058 Nitrous jet and .031 Fuel jet and I've attached pictures of one of the plugs. I'm not an expert, but I think the plugs looked okay, the timing mark was almost to the bend and the fuel didn't look too rich (I killed the car at the end of the pull, so there was no idle time on the plugs). However, after I made the pass, my car wouldn't want to idle. It runs fine once I'm going, but it struggles to find idle and keeps shutting off. What would be causing this? Have any of you had problems with your idle after switching plugs?
Jets are backwards .058 fuel .031 nitrous I doubt it could be the plugs causing this problem. How did the car idle before the pull?
I double checked and the jets are correct, it should be .052 nitrous jet for a 100 shot, and if they were backwards, the plugs would look much worse. The car revs and drives fine, with no backfires or misses, so I'm guessing it is the idle tune. I'm guessing my tune wasn't that great in the first place because after I installed the cam, my car would occasionally die when my air conditioning is on. Thanks for input.
The first pic you posted shows the fuel ring, it should be about 1/8 inch off the base of the lip. Get fuel right first then focus on timing but always stay of the SAFE side of timing while getting fuel correct.
