Can u port out a n.o.s ls2 nitrous plate to fit 95mm intake combo
I have a ls2 nitrous plate from n.o.s I was using in a stock ls3 intake on another project...no I wanna swap it in to my 418ci I'm currently running a ported 95mm fast with matching 95mm tb....has anyone ever ported it out one of these plates to match there Intake setup?
Your best bet is to buy the plate that's posted above. It is also a much better plate.
As far as machining the plate you have its pretty easy to see where the discharge paths are. Its basically just a single nozzle discharge machined into a plate. Just measure it out and compare it.
Dave
Dave
