SLP lid fitment question
I had quite hard time fitting the round inlet of the air lid onto my MAF. It took quite a bit of careful sanding and grinding to make it fit properly. I should add that I made sure that I blew out with air and then wiped out the inlet to make sure that no particle got on the MAF. The sealing area around the filter fit well. I just got mine from Summit last month.
It turned out ok, but it was way more work than I expected.
Hmmm.
So, a recap: Lids almost all have problems, and there aren't many other options. Crap.
Who has tried the Volant intakes for the Camaro? To be honest, I don't trust the sealing of the SLP lid at *all*.
Edit: I just looked at my SLP lid a bit better. It's all sorts of warped and crooked. It *has* to be an older one, as I can see a seam where two pieces were 'welded' together at the bottom of the MAF sensor socket.
The SLP's Blackwing lid fits perfect every time but are expensive if you can find a good quality used. The $99 SLP lid is horrible in quality and fitment. The lid has a small gap at the rear of the lid and requires weather seal foam which SLP supplies if you buy one new. If you don't have the lid sealed at the back then debris is entering your intake and not passing through the air filter correctly.
Pontiacerator
I have a new slp lid, well bought few months ago, fit is great on the box, the neck is ridiculous. heated it up over the stove burner for 8 mins till it softened, then it went on. I doubt it will ever come off.
It's not mine! woo hoo!
I also have the newer SLP lid and I'm very happy with it. The MAF is supposed to be difficult to get in -- that's what keeps it in! I simply heated the opening up with a hair dryer to get it wedged in there.
Also, while the SLP lid fit a bit loose with a factor paper filter, I switched to an Airaid dry filter and it fits perfect now. Just something to keep in mind before discounting the SLP.
From what I've heard, Volant intakes fitment can be hit or miss also. Aftermarket lids are all hit or miss on fitment. Some fit well & others don't fit well at all. SLP lids are made the best though. They've invested the most money into manufacturing their lids & it's resulted in the most durable material. Many others have a tendency to crack because they aren't manufactured at the same level of quality as the SLP lids.
Good luck with whatever route you choose.
I just installed one this weekend on a 2002 WS6 and the fit was very tight with a Wix air filter. I added the weather stripping in the back and it took a while to push the rear tabs into place. How do you know if you are fully down and sealed? Mine won't move at all but if you look at the rear it does look raised but I am just wondering if that is because the Wix is thicker and I applied the included weather stripping? I just don' t want unfiltered air going in and all.
