whats an electric cutout?
Old 05-25-2013, 08:52 AM
ACL Z28's Avatar
Default whats an electric cutout?
help ls1tech!
Old 05-25-2013, 12:43 PM
Nathan C's Avatar
It uncaps your exhaust so you are basically bypassing the muffler. Quick Time Performance sells them as do other sponsors.
Old 05-25-2013, 02:13 PM
sawblade99Z's Avatar
^That. And a regular cutout requires you to get under the car and take the cap on and off yourself, whereas an electric one is controlled by the flip of a switch you put inside the car.
Old 05-25-2013, 02:15 PM
Fry_'s Avatar
http://www.quicktimeperformance.com/QTEC/index.php
Old 05-27-2013, 02:13 PM
Forcepower's Avatar
good piece if you buy one
Old 05-27-2013, 02:15 PM
Randolph Ziskey's Avatar
very true...very good piece.
Old 05-28-2013, 07:58 AM
ACL Z28's Avatar
How much should I be paying for one? and is there a horsepower increase with having one?
Old 05-28-2013, 03:02 PM
2000PewterT/A's Avatar
Horsepower will increase a little if you have a restrictive exhaust, but if your have a well designed and good flowing exhaust power changes will be so small it wouldn't be worth the price IMO, I suggest if you want a quiet car and the ability to make it loud and quiet again cutouts are a great option.
Old 05-30-2013, 05:18 PM
pnykillerz28ls1's Avatar
They range in price depending on quality but I wouldent cheap out on an electric one because I have seen people complaining about how they leak or don't function well
Old 06-01-2013, 04:56 PM
LASTOFTHEBREED02T/A's Avatar
I got a non electronic cutout for 28bucks at summit racing. 200 bucks for them just ain't happening....
Old 06-06-2013, 04:32 PM
Midnight02's Avatar
I like to think of an electric cutout as the door which opens to unleash the LS goodness that lies within! Haha.
In short, yes there's a power increase that has been dyno proven many times. You could expect to see less of an increase if you already have a higher flowing exhaust. You could expect to see more of an increase if you're highly modified.
My $.02. You don't want a cheap cutout. They are subjected to high amounts of heat and the seals (when closed) constantly have pressure on them. I went with a QTP. The first one I had didn't function properly however they have a new design that appears to be much more durable. Had mine on for well over a year and it works flawlessly -- opens and closes when I hit the button, no leaks, etc.
The best benefit I get from this over a manual cutout is that I can partially open the valve (30%) and get the added volume to the exhaust note while maintaining the tone of the mufflers. You get better flow and better sound without the rasp.
Quick Reply: whats an electric cutout?
