T56 Clutch Easy Bleeder
I finaly got tired of trying to bleed my buddies 2003 Infinity that we swapped over to a LS1 and T56. We installed a remote bleder hose line but still have to sit there and pump the pedal and open/close the bleeder screw a hundred times. Total PITA.
I then tried a MityVac with a speed bleeder screw instead of the tiny motorcycle sized bleeder screw. That tiny thing constantly leaked cause it had not sealer around the threds and was another PITA. Then I decided to make an affordable version of a pressure bleeder.
Total investment is probably less than $20. The only improvement I suggest is to get some type of rubber mat for the seal rather than a piece of semi-rigid plastic that I used. It seals, but still dripped a little as there is little room to fit next to the ABS module and brake booster.
Here is simply video showing the parts and layout.
