Pontiac GTO 2004-2006 The Modern Goat
Hi, I am new on here from OHIO, GTO 2006
Old 05-31-2013, 09:31 AM
Jamie Kuhn's Avatar
Smile Hi, I am new on here from OHIO, GTO 2006
I just bought this 2006 GTO and do believe it has been lowered. I want to raise the back end up because it bottoms out too easy. How do I tell what springs were used if it was lowered and what are my best options to fix it?
Attached Thumbnails Hi, I am new on here from OHIO, GTO 2006-001.jpg   Hi, I am new on here from OHIO, GTO 2006-002.jpg
Old 05-31-2013, 09:45 AM
sopes's Avatar
Can you get some pics of the under side and springs? what is the height from the floor to the wheel well lip ? Just based off these pics it looks almost stock height. Check the springs for a sticker and see if it has an ID left on it
Old 05-31-2013, 09:53 AM
Jamie Kuhn's Avatar
I will have to wait till I get home. Then I can do it. Thanks!
Old 05-31-2013, 10:46 AM
ElGuapoK20's Avatar
Not that I've seen many GTO's in person to reference ride height but it looks lower than stock. I think it's rubbing the tire more than bottoming out though, there seemed to be more travel before the bump stop hits compared to room between the fender and tire sidewall.
I forgot to check your tires' size (height) versus stock tire size (height). Those wheels do have a lower offset which pushes them out more than stock, but it looks nice.
Old 05-31-2013, 03:47 PM
Jamie Kuhn's Avatar
I am getting pix here in a min. but the tire size is 245 40zr18. The distance is 26''. The springs look stock, black and the numbers 92100087.
Attached Thumbnails Hi, I am new on here from OHIO, GTO 2006-img_0191.jpg   Hi, I am new on here from OHIO, GTO 2006-img_0193.jpg
Old 05-31-2013, 04:47 PM
sopes's Avatar
that part number is a stock gm spring, that is def the stock height, try setting your tire psi to the max cold you mihg tbe able to gain a little clearance
Old 05-31-2013, 05:08 PM
Jamie Kuhn's Avatar
is there any spacers you can put in the springs.
Old 05-31-2013, 10:15 PM
sopes's Avatar
autozone and such places used to have a screw in style lift for the spring. not real pretty but it may give ya a little boost
Old 06-07-2013, 05:26 AM
Ian Johnston's Avatar
What are your shockers like? May need a decent set of gas shocks. Height looks about stock, maybe 1" lower. Both my daughters cars are much lower than that.
Old 06-07-2013, 07:34 AM
madskater5's Avatar
First, welcome to this world and specifically the GTO.
I can't believe no one here has solved this yet...
OK. Yes you have a stock spring, but that is NOT stock height. Our GTO suspension comes off the boat SCREWED. It's flattened, squashed, and not that great. Rumor has it this is due to being tightened down too hard when they got shipped here. Springs are cheap, just buy new ones. I know you are really wanting to dig into power mods, but your best bet is to drop a few hundred into poly suspension bushings first. You WANT power, but your car NEEDS fixed suspension.
For reference, I've attached a picture of my GTO. I have an aftermarket stiffer STOCK HEIGHT spring in the rear, the front is a .8 drop spring. My wheel/tire combo is a little taller, but you get the idea.
Attached Thumbnails Hi, I am new on here from OHIO, GTO 2006-2012-09-12-18.01.23.jpg
Old 06-18-2013, 12:42 PM
Jamie Kuhn's Avatar
Default The car was lowered
I have been working so hard to figure out what's up with my GTO. IT WAS lowered. The dealership is going to pay to restore to original condition. Thanks for all your advice!
Old 06-18-2013, 12:45 PM
Closed ex-Sponsor Account
Bell Automotive Todd's Avatar
(Late) welcome to the forum! So how exactly was it lowered using stock springs? Where they cut?
Old 06-19-2013, 05:55 AM
Jamie Kuhn's Avatar
the whole nine yards. springs and stabilizer links
Old 06-19-2013, 07:07 PM
LS BRAVADA's Avatar
one of my favorite cars. looks like a holden monaro
Old 06-24-2013, 10:35 AM
Jamie Kuhn's Avatar
Default in the shop
The car is in the shop getting the suspension fixed. Will have pics later.
Old 06-25-2013, 12:32 AM
madskater5's Avatar
What new stuff are you going with? Stock replacement or aftermarket stuff?
Old 06-26-2013, 08:45 AM
Jamie Kuhn's Avatar
Default stock
new pic
Old 06-26-2013, 12:09 PM
Slo4's Avatar
Uh, from the pictures and from others' comments, looks like typical stock rear spring sag.
Anyways, welcome to the herd.
Old 07-09-2013, 12:46 PM
Jamie Kuhn's Avatar
Default rear tire
Well after all the new suspension work, the rear tires still rub but not as bad. The tires are just too wide for the car. I think rolling the fenders or trimming them might help, but not sure if it will solve the issue. Any one want to buy some tires and rims? lol
Old 07-09-2013, 03:20 PM
Senetonix's Avatar
clean ride!
Quick Reply: Hi, I am new on here from OHIO, GTO 2006
