tranny question
Depends on the engine type. If your using an LS it will be pretty straight toward if using a lt or small block then you will have to change or modify the midplate. The offset lever will have to be changed for the f body shifter use on the gto. The gto is an LS t56 wither different internals and a. 2.97 first gear ratio and a junk extended shifter assy
