Car in Batch fire mode (Back fires when trying to start)
Old 06-04-2013, 07:50 PM
IMPRTKILLER's Avatar
Default Car in Batch fire mode (Back fires when trying to start)
I swapped a LS2 6.0 408 into my 99 Camaro. When i try to start it sometimes it backfires but then next time u try to start it will fire. It says its in batch mode and my cam is producing 0 ohms resistance. Gonna see if i have the wrong cam sprocket but other then that what do u guys think is wrong? I bought the racetronics cam sensor extension harness. I have swapped the outside wires around and that didnt seem to fix the problem. How can u check the harness to see if each pin has the right amount of signal.
Old 06-04-2013, 07:51 PM
It has the half moon timing sprocket and a 24X reluctor wheel and it has the LS1 cam gear. It had the VVT timing but i converted it over so it doesn't have that now
Old 08-15-2013, 05:32 AM
R32WA's Avatar
Did you ever find a cause for this? I am having the same problem, some times its starts perfect the next few times it back fires or just cranks and wont fire at all.
Old 08-16-2013, 07:14 PM
LS1MCSS's Avatar
Are you sure it's a 24X reluctor, and had VVT?
Quick Reply: Car in Batch fire mode (Back fires when trying to start)
