Passenger side airbag
FYI, if you just unplug it neither airbag will work since the system is tied together. So the easiest is to just pull the fuse and ignore the dash light, or wire in at least 1.3 ohm but no more than 3.7 ohm resistor(PS airbag). Then the dash light will stay off and the DS airbag will still be operational. I've found that after a few months even with 1W resistors they usually will need to be replaced, so you might want to try a 10W resistor. Also don't forget to factor in the resistance variation to prevent any possibility of the ohms being to high/low.
