Aeroforce Scangauge/Glowshift Wideband problems
Old 06-08-2013, 07:42 AM
ascastil's Avatar
Default Aeroforce Scangauge/Glowshift Wideband problems
I wired my wideban on my '97 Camaro to the 12v constant cigarette lighter fuse, and the 12v switched to the dashboard gauges in the fusebox. When I turn the car on, the wideband works but the scangauge doesnt. If I unlug the scangauge from the obd port and plug it back in with the car on, they both work. If I unplug the power from the wideband the scangauge works. Basically, the only way they both work together at the same time is if I unplug the scangauge and plug it back in. I dont understand it. Any ideas? I also tried using different sources of power from the fuse box with the same results.
Edit: Just read on the instructions about wiring a separate power wire from the back of the scangauge to a switched power source. I remember reading on here some people saying they had to hard wire the gauge in. Is this what they were referring to?
Old 06-08-2013, 10:35 AM
ascastil's Avatar
Ran another power wire from the back of the scangauge and it works fine.
Quick Reply: Aeroforce Scangauge/Glowshift Wideband problems
