Need some opinions on a cam
Old 06-09-2013, 11:24 AM
dannyk10's Avatar
Default Need some opinions on a cam
Hey guys I am building a Lq4 with 243 heads Carb intake, turbo 400 trans.
I am looking for 200-250 shot
The cam I am thinking about is for sale in the parts classified section..
The specs are Brand new custom cam from Geoff at EPS. Specs are
LSA 112 226/234 .598/.612
Here is a link:
https://ls1tech.com/forums/parts-cla...ustom-cam.html
Also, Do I need to fly cut the pistons with this cam?
Thanks for all the help in advance.
Old 06-09-2013, 01:24 PM
Blackpanther99's Avatar
Are the heads stock? Or are they milled?
Old 06-09-2013, 01:49 PM
dannyk10's Avatar
Heads are stock for now. I can mill them if need be. Wasnt sure if I should or not yet.
Old 06-09-2013, 06:19 PM
I would get them ported and milled to at least .30 to avoid flycutting.
Old 06-09-2013, 06:23 PM
camscam02's Avatar
milling the heads would increase the possibility that he may need to flycut???
but the cam should clear no problem even with the heads milled .030 but its always the smart move to check ptv
Old 06-09-2013, 09:53 PM
dannyk10's Avatar
Thank you for the help. I would of course check it is nice to know that it should clear even milled. I know milling increases ptv issues.
Think the cam will work well with a nitrous shot?
Quick Reply: Need some opinions on a cam
