Fuse pin replacement?
I'm doing a lil rewiring in my 94 and need one new 2 pole fuse pin.
Local parts stores say dealer only...local dealership sais i hafta buy a new fuse box. Theres a handfull of these in every car in the world...I know someone sells them.
Reopening and using the old one is proving difficult cause they get bent up while prying it open.
If anybody can tell me where to buy these it would be greatly appreciated.
Also,can i upload pics to the site or do i need photobucket or something?
LS1Tech Sponsor
Your question is kinda vague to me. Take a picture of what is it you need and post it up. We may be able to help.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
Not %100 what the actual name of the part is.
https://ls1tech.com/forums/picture.p...ctureid=102061
It slides in the fusebox and can power two fuses.
LS1Tech Sponsor
__________________
1-888-467-4491
1-888-467-4491
Went this morn and checked out a parts car and every fuse pin in it is crimpt...even the terminals with no wires in them. So a used box wont help.
I neede a new uncrimpt pin. Searched the web for hours and cant find any.
As much as i would like to crimp the wires on as they are intended to be, im just gonna solder them to it and move on.
For anyone who may care i read that these are refered to as fuse series pins instead of 2pole like i posted obove.
I cut a wire from the fuse box thinking i could buy this pin at the part store and need to put the wire i cut and one more back in that spot. Theres around 1/8 inch of wire left on it so i cant connect back to it.
Since this was a series conector with only one wire in it a replacement would keep me from splicing or soldering anything.
LS1Tech Sponsor
FWIW, I have some of those terminals here. What guage wire was that?
__________________
1-888-467-4491
1-888-467-4491
LS1Tech Sponsor
14 Ga Blue? If you want a new one, just pm me your address.
__________________
1-888-467-4491
1-888-467-4491
