L92 oil consumption
L92 oil consumption
l rebuilt a L92 for a friend's dad because it was using a quart of oil about every 3,000 miles and was told by the dealer that it needed pistons. I replaced the pistons and did a stock rebuild on the engine. l also installed the oil deflector inside pan. He has now put about 10,000 miles on it since the rebuild and it is still using the same amount of oil. l don't see any signs that it's burning any oil and there is not much oil in the intake either and no leaks. Any ideas as to where the oil is going would be greatly appreciated, thank you.
