Show your gauges
Show your gauges
I'm trying to make my mind up on what style gauges I want to go with. If you have pics of yours during the day and night, post them if you don't mind. Thanks
Allen
Allen
Here is what I put together on a budget. 2-5/8 cluster in a custom panel on the left. Autogage 3" tach mounted to the column. Neat little trick, I used a DPDT toggle switch to wire the temp gauge to a temp sender in the trans and one in the engine so I can use 1 gauge to get 2 temps. Save money and space.
