LQ4 intake swap/injectors?
I recently finished an LQ4 swap in to my 67 Chevelle, I now want to swap the truck intake for an LS6 intake, will I need to replace the injectors and connectors? I'm not building a racecar or a high HP motor, I want a dependable cruiser.
Im in the process of doing this as well. It is my understanding that if you want to run the LS1 car injectors, you will need to have the injector electrical connectors swapped to the car type connector. I chose to keep the truck injectors and purchased injectopr spacers from ebay to allow me to run the truck injectors on a LS1/6 intake. The choice is yours but either way will work.
