p0327 code
p0327 code
I have searched this DTC and have read some valuable information but I still need some help . I have a 2001 Silverado with a 4.8 that threw this code last week . Since the truck has 230,000 miles on it and I was starting to here spark knock on acceleration I figured the sensors were bad so I replaced both of them along with the oil pressure switch since I was there. I inspected the wire harness and it looks perfect so I re-used it .I cleared the check engine light with my scanner and the truck runs great. No more spark knock at all, but the code reappeared . I also replaced the spark plugs too since they were due for a change anyway. I have followed the flow chart on http://www.gearchatter.com/viewtopic8878.php and it seems my PCM is bad according to the results I've gotten . Before I go out and buy a new PCM is there anything else that would cause this code ? Also I thought of swapping my PCM with a PCM from a co-worker of mines truck and see if the code follows it . His truck is identical to mine except that his is a 2000 model. My question is are the PCM's the same or is there some other reason this cannot be done ?
Thanks in advance for any and all help .
Here's the freeze frame at the moment it set the code this afternoon. It only sets the code at HWY speeds between 55 -65 MPH . The truck is running great, way better after I changed the knock sensors . Brand new GM fuel pump was installed at 197,000, truck has 230,000 now .
Abslt TPS % 4.7
RPM 1740
Calc load 6.7
MAF ( lb/m ) 2.04
MAP (H G ) 9.2
Coolant temp 180*
LT FTRM bank 1 3.9
ST FTRM bank 1 -7.0
LT FTRM bank 2 3.9
ST FTRM bank 2 -7.0
Speed 63 MPH
Fuel systems 1 and 2 closed
Abslt TPS % 4.7
RPM 1740
Calc load 6.7
MAF ( lb/m ) 2.04
MAP (H G ) 9.2
Coolant temp 180*
LT FTRM bank 1 3.9
ST FTRM bank 1 -7.0
LT FTRM bank 2 3.9
ST FTRM bank 2 -7.0
Speed 63 MPH
Scan capture looks pretty normal, so nothing really suspect there. Being that the code is an electrical fault code, and you've checked wiring (I'm assuming all the way to the PCM bulkhead), I think you're probably right on track with the PCM being the issue.
As far as a direct swap of PCMs with your friend, 2001-2002 shows to be the same according to my interchange software...as long as it's a 4.8. Can't say what the difference is from the 2000, but it does not appear to be the same. Someone else might chime in here....
I hear ya. I recently had a customer come in that had been running his car (that had been "tuned" by someone else previously) with jacked timing/mis-matched tables,all o2 sensors shut off...but still a "closed loop" tune.....for 3 YEARS! All the while, he was beating the hell out of the car. I'm totally amazed that the engine held together. Proof-positive that these things are tough! lol
Update
Today on the way home from work the Service Engine Soon light turned off on it's own. This was after 3 cold starts and driven under the same conditions that threw the code in the first place . Is it possible that the PCM had to go through the 3 cycles to familiarize itself with the new sensors vs me turning the light off with my scanner ?
