F1a vs. F1c....Procharger guys help me!
Old 06-24-2013, 10:47 PM
SERB Z06's Avatar
Default F1a vs. F1c....Procharger guys help me!
Well I'm going to be sending in my F1a to Procharger very soon here and I'm thinking about just paying the $500 for the F1c upgrade while its there. I know the only change is the volute, my questions are:
1) Is it worth it?
2) If answer to #1 is yes, will it still be worth it if I am running an 8 rib belt setup? I have heard to not go past the F1a unless I can do to 10 rib or cog. Keep in mind I'm doing this with a Corvette so we have much better bracket options than the F-bod guys out there do (no offense)
Old 06-24-2013, 10:59 PM
I8UR4RD's Avatar
id wait and go f1-x
Old 06-24-2013, 11:11 PM
SERB Z06's Avatar
I already have an F1A....that's like saying I shouldn't mod my C5Z and just wait and get a C6 ZR1
Old 06-24-2013, 11:48 PM
jt76's Avatar
What cubic inches are you going with? What are your goals? My friend had a D1Sc on the 370 in his firehawk, then upgraded to the F1C... it FELT faster with the D1 but the top end on the F1C was nuts... i think the F1A would be the perfect blower on most cars..
Old 06-24-2013, 11:52 PM
Detoxx03's Avatar
Depends on your goals. If the A is peaking early then get the C.
Old 06-25-2013, 12:26 AM
SERB Z06's Avatar
347
Goals are 900-1000 highway roll monster
Old 06-25-2013, 01:33 AM
Detoxx03's Avatar
If its only $500 I would definitely get the F1C. What are you making for power now?
Old 06-25-2013, 01:50 AM
SERB Z06's Avatar
Was making 750 with a T-trim stock motor...changing a lot now
Old 06-25-2013, 07:35 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
There's always Steve Morris if you want to have the volute ported. I know he has done some amazing things with Prochargers in terms of modifying them, so I'd contact him and see what he says. Couldn't hurt to make a phone call.
Old 06-25-2013, 07:51 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Originally Posted by SERB Z06
347
On a 347 the F-1A should give you all the boost four bolt heads can handle, unless you're running at higher elevation. You should be able to see 20 psi with an F-1A on a 347 at 0-1500 ft elevation, and it doesn't take as much hp to turn it as an F-1C will. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 06-25-2013, 08:12 AM
I8UR4RD's Avatar
i just figured if your going through the trouble of getting a 10 or 12 rib or cog setup and are going to have another 500 to throw at a blower, then why not go ahead and step up to the X. thats definitely a mod. supposedly its easier to turn than the F1-R you were considering. buy a big pulley and keep the boost down, i didnt realize you were on a 347. i highly doubt youll outgrow the A
Old 06-25-2013, 12:56 PM
SERB Z06's Avatar
Thank you for the advice. Do you have any experience over spinning the F1A?
Old 06-25-2013, 03:07 PM
LS1Tech Sponsor
You're welcome. We were overspinning mine when we were driving through the converter, but I don't recommend it. Bob
__________________
Old 06-25-2013, 08:26 PM
I8UR4RD's Avatar
ill be spinning mine at 76k
Old 06-25-2013, 10:28 PM
DopeFedZ's Avatar
Can a D1 make 900+? My buddy is making about 840 with his D1 and a 347
Old 06-26-2013, 05:20 AM
LS1Tech Sponsor
I've never seen it happen. Bob
__________________
Old 06-26-2013, 03:56 PM
UNDER PRESSURE MOD
Can it, maybe... with a higher compression motor, m6 with a light drivetrain, lots of meth so you can push the timing... will it last, I doubt it. 840 is a healthy number.
Old 06-26-2013, 04:03 PM
Blackpanther99's Avatar
Agreed^^
Old 06-29-2013, 12:44 PM
Detoxx03's Avatar
In terms of efficiency is the F1A more efficient than the F1C? I know its setup dependent but want to grab one of them at some point on a built 376 M6 with either Mast small bore LS3 heads or the new trick flow 255 heads. More power its makes the better plus less heat.
Quick Reply: F1a vs. F1c....Procharger guys help me!
