What size coupling??
Old 06-29-2013, 12:31 AM
02ls1gun's Avatar
Default What size coupling??
Ive been searching and cant find a clear answer. What size of coupling do I need to go from a FAST 92mm TB to a SLP 85mm MAF? Length? Also has anyone had any issues hooking up a 85mm MAF to a FTP 98mm lid. Thanks for the help!
Old 06-29-2013, 12:42 AM
99Bluz28's Avatar
I've had the best results using the stock coupler with my 85 MAFS and NW 92mm TB.
Now if you don't want to use the stock coupler then measure the MAFS outlet and TB inlet to get your sizes and you'll need it with a 15* to 22* bend.
I found a 3.5"/4" silicone reducer w/22* bend at turbohoses dot com, it's pricey but should work perfectly!
Old 06-29-2013, 02:10 AM
02ls1gun's Avatar
Thanks for the help!!
Quick Reply: What size coupling??
