Door Striker bushing
Old 06-30-2013, 08:49 PM
crosstraining's Avatar
Default Door Striker bushing
Does any one know where I can get a the little bushing from a door striker for a 72 Nova?
Thanks
Old 06-30-2013, 10:19 PM
i r teh noobz's Avatar
Google shows a bunch of replacement striker bolts. I'm sure dorman makes a bushing.
Old 06-30-2013, 10:26 PM
ls1nova71's Avatar
They used them on all novas up until 79. I usually get them off 4 door rear doors since they have less wear. Camaros used the same ones . Probably a lot of other cars used the same if you have any pick a part junk yards.
Old 07-01-2013, 03:10 AM
tfi racing's Avatar
OK,I'll fall for this gag as well.You can't be serious,really?
Old 07-01-2013, 09:41 AM
I found several also. I was hoping someone knew where I could just find the bushing. I'll keep looking.
Thanks
I don't live very close to a good parts yard. If I can't find just the bushing, then I will just pick up a the whole striker bolt.
Thanks
Why waste your time typing this just to be a D-Bag
Old 07-01-2013, 05:39 PM
Try GM. They might still have them if its shared with newer cars.
Old 07-01-2013, 06:46 PM
ls1nova71's Avatar
I would replace the whole bolt. The big washer isn't designed to come off to replace just the bushing. I suppose it can be done but won't be as easy as just taking it apart. Just an fyi in case you weren't aware.
Old 07-01-2013, 07:19 PM
Thanks, I will check into that
I did not know that. I have not taken it off yet. I will buy a new striker bolt then.
Thanks Ls1nova
Old 07-01-2013, 10:57 PM
stangtrader's Avatar
Check your local parts store.the have them in the dorman/motormite section
Quick Reply: Door Striker bushing
