Do Spec LS1 aluminum flywheels take standard bolts instead of metric?
EDIT - It's M10 x 1.5 like it's supposed to be, just took a socket to get started. Machine shop tech was wrong and tried to use 3/8 x 16 saying the metric ones wouldn't work. It doesn't appear the threads are damaged. I ran the proper M10 bolts in and out a couple of times and the pressure plate installs fine and torques up.
My ARP pressure plate bolt kit won't thread into this Spec aluminum flywheel. Did Spec "spec" standard bolts for some reason?
Also, anyone know the torque spec on the pressure plate bolts for the aluminum flywheel?
~Brian
~Brian
