2000 408cubic inch Procharged Ws6
Year: 2000
Make: Pontiac
Model: Trans Am
Price: $17500
Mileage: 29523
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Beige
Transmission: Automatic
LS Engine?: Car has LS engine
Engine
Texas speed motor
GM6.0L Cast-Iron Engine Block
Eagle LS1 4.00 Stroker Crankshaft
Eagle Ls1 6.125 H-Beam Connecting Rod Set with upgraded ARP 2000 Rod bolts, 2.100 Crank Journal, .927 Wrist pin Diamond Racing forged piston set 4.005 Bore, 4.000 Stroke, 6.125 rod length, 1.115 CD, -28cc Dish, Includes HD H-13 Wrist pins
Diamond Racing Plasma Moly Piston Rings with Upgraded Steel Top Ring, 4.005 Finished Bore. ETC. Etc
Precision Race Components LQ9 Stage 3 Cylinder heads 2.08 Intake, 1.60 Exhaust Value, Fully Assembled with PRC Spring Kit
Texas speed Giant camshaft : 248/254, .622/.614, 115 LSA
Texas speed Chromemoly 7.40 Pushrods
GM LS7 lifter Kit
Cometic MLS ls1 Cylinder Head Gasket, 4.030 Bore, .40 thickness. ETC
Misc Stuff
tremec transmission, TCI Racing Flywheel , trans cooler, 4200 stall convertor, Qa1 Adjustable shocks, 4.10 gear, Dual walbro fuel pump, Full exhaust longtubes to mufflers to cut outs 3 inch. Fast Intake manifold, Fast 90mm throttle body, 60lb motron injectors, Autolite boost gauge, and temp gauge, new starter, 315 BF Goodwrench nittos, Alumium driveshaft, nchect radiator. Twin fans 16inch and 14inch
Computer
Fast XFI and Fast ECU
D1sc procharger Twin intercoolers (12-14lbs)
