I need your help having a bad clunk help help help
Old 07-14-2013, 07:43 PM
fbird38's Avatar
Exclamation I need your help having a bad clunk help help help
I have a 1996 firebird lt1 I'm having a hard clunk when I get out of the gas when I'm getting on it I have put a new trans mount torque arm mount and new u joints the car also has headers and no cats I have no idea what it could be the clunk feels like its under the center console can any one help me out pleaseeee
Old 07-14-2013, 07:51 PM
RamAir95TA's Avatar
Are the headers hitting the floor pan?
Old 07-14-2013, 07:56 PM
fbird38's Avatar
I don't thing so after I put the on I had a real bad vibration I replaced the motor mounts and it went away
Old 07-15-2013, 11:38 AM
ahritchie's Avatar
Clunk under the console as almost always the trans mount (you sure it's not the y pipe banging around?).....did you replace it with another rubber OEM POS? Are you getting excessive shifter movement upon hard acceleration? If so, it's probably broken again...I put in a factory one just to break it less than a week later, don't bother with the rubber ones, they are weak get nice aftermarket poly trans mount and you won't have to keep buying them.
Old 07-15-2013, 07:41 PM
ugod02010's Avatar
+2 with the factory rubber trans mount.. Also have you checked your universals on the driveshaft.
Old 07-16-2013, 11:31 AM
fbird38's Avatar
Thanks I guys it was my bran new poly trans mount the center bolt was broken off
Old 07-16-2013, 11:39 AM
ugod02010's Avatar
That's usually right where they fail. I will be doing mine real soon. Well after I get rid if this damn missfire
Old 07-16-2013, 12:00 PM
fbird38's Avatar
Look in to NGk v power plugs it took care of my missfire
Quick Reply: I need your help having a bad clunk help help help
