Willizm's TA vs Byron's Dragway(vids/slips)?
So I went to Byron to run the TA for the first time. Keep in mind that I've never ran the TA at the strip before so my expectations were conservative as I was just looking to dial in some things and get a feel for a launch. I just hoped that I could get in the 10's and not break anything. I also wasn't going to race the tree. I wanted to get seat time and get a routine/launch down before I look to race the other guy.
The car is full weight with absolutely no weight reduction outside of the spare tire that was removed to make room for the battery box. I have no cage in it and the wheels on the car are the same I drive on the street. No slicks/skinnies here. Just 17" TTM's with MT ET's on the rear and big ol 275 wide Nitto 555's up front. My suspension is basic adjustable UMI type stuff.
Mods: See sig. Car made 735whp/920wtq on a mustang dyno at 17psi on e85.
10psi passes would put me at around 575-600whp. 13psi would be around 650whp.
1st pass. I ran on wastegate spring pressure which is set at about 10psi and decided to mildly foot brake car to get a feel for the car on the track. I did a rather gay burnout but hell thats me getting used to the process of backing into the water box. I staged and got ready for the light. It bogged hard off the line with the track being so sticky and me not giving enough rpm. It got me a lousy 2.1 60'. First run was 11.040@139MPH
2nd pass. I kept the car on 10psi and decided to test the tbrake out to see if I can get a good launch and still wanted to keep the boost conservative to get a feel for it. This time I staged the car and hit the button. I gave it some rpm and could hear the turbo spool. This got me a better 60' (1.7) but still didn't leave as hard as I would have liked to. **** yeah, second ever pass and I ran a 10.5@135mph. This is getting interesting since i'm on such low boost still.
3rd pass. This is my best pass of the day. Still running on 10psi and using the tbrake. I gave it a bit better burnout this time. I staged the car and hit the button. I gave it some rpm and as soon as I saw the first light hit I floored it down and let off the button once I heard it spool fully. unfortunately the time it takes to spool the turbo is longer than it takes the tree to light up. I get a little better 60' at 1.6. I'm not sure what to expect with 17' drag radials, but figure that isn't too bad. Car ran great on this pass and could feel it spin a little past the 60' mark, but not too much. Ran 10.4@134mph.
Last pass. I'm elated to know that on my lowest boost pressure i'm deep in the 10's pretty easily. I feel good about how the car is handling and feel comfortable bumping up the boost a little. I set it to 13psi and do a nice healthy burnout. I get staged, hit the tbrake, mash that bitch to the floor and let off the button. Best launch of the day and a little quicker than my last 1.6 by a couple hundredths. As I get up toward the backhalf I could feel and hear the car break up a little and it wasn't pulling as hard as it should be. I ended up running a 10.9@127mph.
I have to pull some plugs and see what's going on. The day was getting pretty hot and humid at 90* and swamp *** all day. I figure i may be blowing the plugs out with more boost. I'll replace them, tighten up the gap and also check for some boost leaks. Overall, i'm happy with what I ran and feel I have a solid 9 second car once I clear up the issues and can run full boost. I suprised alot of people with the car considering it doesn't sit on some skinnies with big 28" rubber out rear and appears pretty stock.
Not going to lie, it was nerve racking leading up to the track day, but surprisingly the car did not have any drama for me coming out of the hole. Street driving this car is sketchy when I go wot, but being on the track was highly predictable and drama free.
I was there with the hugger.
Didn't do what I wanted to do.
Need some time behind the wheel now that I can shift it like a **** with the tick master.
Didn't heat the new nittos like I should and spun but had a ball launching it at 5k and it was hard to break habit of not revving past 6k to get into gear.
We shall do it again soon.
Will's car was rockin while we were dying in the humidity and heat...Lol
My best
60.......1.852
330.....5.106
1/8......7.788
MPH....96.75
1000....10.096
1/4 ......11.976
MPH.....119.26
http://m.youtube.com/watch?v=UOQAo35Td6k&feature=plcp
My best
60.......1.852
330.....5.106
1/8......7.788
MPH....96.75
1000....10.096
1/4 ......11.976
MPH.....119.26
great runs Will!! sounds like it'll be flatout badass once you get it dialed in. looks like it pulls like a mf'r too.
Jay, nice run as well. very respectable and will be even better once you get the nittos broken in and use to them.
hope to get to the track this summer with you guys and have some fun.
