Can I make this look any better?
Easiest way i find is to remove the black plastic piece inside the wheel well, it has 2 trim push pins attached to the fender , 3 small bolts that screw into the body and I believe 2 bolts that attach to the under side of the front bumper ... There may be more, it's been a minute since I last removed it , but that will give you access to the bolts that attach the front bumper and fender together.
