No oil pressure at startup. Then fine. WTH.
First off this is a LC9 V8 in my 08 Chevy Avalanche. It is an 5.3L iron block LS like engine with active fuel management (turns off 4 cylinders under light load).
I have applied for a login on the Avalanche boards but I am waiting for approval but I think you guys might be able to speak to it just as well. On to my issue.
My engine was off for about an hour and when I went to start it, the dinger went nuts and said low oil pressure and to turn the engine off which I did. I then restarted it and noticed the lifters were ticking from bleed down therefore the panic kicked in and I shut it off once again. BTW, oil level is fine.
I then waited a few minutes and tried once more and the oil pressure came up and the engine ran fine.
I clearly believe the pressure was low or NON-existent cause of the ticking lifters so I don't believe it is sender or gauge related so something wigged out in the oil system.
Thoughts???
Thanks.
Bill
Thoughts???
Thanks.
Bill
Am I correct in saying the 10296 is the high volume pump? Knowing what I know about SBC and LT1, there might not be a need for extra pressure. Should I use the M295 standard pressure instead since the overall pressure is normal, except for the one incident?
I'd try replacing the oil filter before opening up the engine for surgery. A defective anti-drainback valve (round rubber/silicone disc inside the top of the filter canister) can allow the oil circuit to empty back into the pan after shutdown and take a long time to refill and generate pressure.
Just grab a good brand that's convenient...Purolator or Wix...and fill it up w/ oil before installing it. Worth a shot.
