No oil pressure at startup. Then fine. WTH.
Old 07-19-2013, 10:55 PM
wrd1972's Avatar
Default No oil pressure at startup. Then fine. WTH.
First off this is a LC9 V8 in my 08 Chevy Avalanche. It is an 5.3L iron block LS like engine with active fuel management (turns off 4 cylinders under light load).
I have applied for a login on the Avalanche boards but I am waiting for approval but I think you guys might be able to speak to it just as well. On to my issue.
My engine was off for about an hour and when I went to start it, the dinger went nuts and said low oil pressure and to turn the engine off which I did. I then restarted it and noticed the lifters were ticking from bleed down therefore the panic kicked in and I shut it off once again. BTW, oil level is fine.
I then waited a few minutes and tried once more and the oil pressure came up and the engine ran fine.
I clearly believe the pressure was low or NON-existent cause of the ticking lifters so I don't believe it is sender or gauge related so something wigged out in the oil system.
Thoughts???
Thanks.
Bill
Old 07-20-2013, 06:32 AM
litle88's Avatar
Oil pump kaput! Get a melling.
Old 07-20-2013, 06:40 AM
wrd1972's Avatar
Is this a typical failure?
Old 07-20-2013, 07:21 AM
litle88's Avatar
Yes the GM pumps suck, the valve relief will stick due to the materials the pump is made if. Get a melling 10296 and leave the lower pressure sping in it. I just hope your lifters and cam are ok.
Old 07-20-2013, 07:57 AM
wrd1972's Avatar
I think the cam and lifters are ok. The pressure seems normal and I had to drive it about 100 miles after it happened and there were no strange behaviors or noises.
Am I correct in saying the 10296 is the high volume pump? Knowing what I know about SBC and LT1, there might not be a need for extra pressure. Should I use the M295 standard pressure instead since the overall pressure is normal, except for the one incident?
Old 07-21-2013, 04:57 AM
crainholio's Avatar
I'd try replacing the oil filter before opening up the engine for surgery. A defective anti-drainback valve (round rubber/silicone disc inside the top of the filter canister) can allow the oil circuit to empty back into the pan after shutdown and take a long time to refill and generate pressure.
Just grab a good brand that's convenient...Purolator or Wix...and fill it up w/ oil before installing it. Worth a shot.
Quick Reply: No oil pressure at startup. Then fine. WTH.
