4.8 1500 with 5.7 e fans
Been done many times. Remove stock shroud and mechanical fan. Drop in fans and use stock upper mount holes. Cut a pair of straps to connect the holes to the plastic shroud on top and bottom. Import the f body fan settings into your file. Wire them up using f body wiring diagrams found on google images. Pretty simple.
