76mm street Nova runs 8.39/163.75 mph!
Old 07-28-2013, 07:16 PM
9 Second Truck Club
stock48's Avatar
Default 76mm street Nova runs 8.39/163.75 mph!
Finally got a halfway decent hit on the car. Running the new billet S476/92/T4, on my factory bottom end 317 headed 6.0L. Drove car to and from track an hr in 100 deg heat then raced it in mid 90 deg temp hot off the street. Crowded hot slick fri night tnt track 3300' Da. No comp lic yet so only got 1 1/8 mile and 1 1/4 mile pass. Still running car off the foot brake, still afraid to try the trans brake lol. I somehow blew an injector out of the fuel rail and let out a little early when I saw the fuel spraying on windshield. Thought engine blew. Lucky there was no fire. Have some crappy vids but pos at&t internet has been down all weekend. All I have is my phone.
Slip reads:
R/T -.045
60" 1.364
330' 3.557
1/8 5.416/132.14
1000' 7.027
1/4 8.39/163.75
Old 07-28-2013, 07:27 PM
T/ALT1's Avatar
Wow! I knew it would fly!!
Old 07-28-2013, 07:36 PM
S6000's Avatar
Damn. Congrats!
Old 07-28-2013, 07:41 PM
Blackpanther99's Avatar
Thats rolling the F out! Congrats!
Old 07-28-2013, 07:43 PM
gnx7's Avatar
3300DA and you still run a low 8!
What tires/transmission/gears out back?
e85? what fuel pump setup?
Old 07-28-2013, 08:11 PM
Beanslsxnova's Avatar
8.39/163 out of basically stock motor. In a street car. wtf is the world coming to haha. Congrats man your car is ******* unreal!
Old 07-28-2013, 08:24 PM
a-low's Avatar
what cam are you running ?
Old 07-28-2013, 08:29 PM
mrstepheneades's Avatar
Junkyard GM engines running big money engine times. Dang so impressive. Yeah give us a run down of specs. We already know 6.0 with 317s.. obviously a cam. What psi for this awesomeness lol????
Old 07-28-2013, 08:38 PM
bad6as's Avatar
wtf, i quit
Old 07-28-2013, 08:41 PM
Camaro9969's Avatar
So awesome!! what's changed in the bottom? Stock ring gap?
Old 07-28-2013, 08:45 PM
I8UR4RD's Avatar
^^ haha hes prob really light weight and running a glide man. either way thats really fast. still has the transbrake to look forward to. Time to pull the chute on that badboy.
Old 07-28-2013, 08:54 PM
9 Second Truck Club
stock48's Avatar
Thanks guys. Car is 3300 lbs full interior street car with stereo back seat etc. cam is my stg 2 truck cam 218, .570", 112 lsa. Boost was 23 psi, and 15 deg of timing. Engine is factory crank, pistons, and rods all GM tty bolts in lower end. Has been cleaned and dingle ball honed with new GM rings. Zero machine work on block and only a surface on heads. Heads have a mild port with stock valves.
Old 07-28-2013, 08:55 PM
Thats insane! Lol
Old 07-28-2013, 08:56 PM
9 Second Truck Club
stock48's Avatar
3.23 gears, and 1.76 glide.
Old 07-28-2013, 08:59 PM
LS1NOVA's Avatar
Originally Posted by bad6as
wtf, i quit
THIS
Congrats on a bad *** run.
bad6as's Avatar
Old 07-28-2013, 09:01 PM
jleews6's Avatar
AMAZING!!!!!
With that cam being on the small side you must not have to spin it to high? When you went 127 to the 1/8th I thought that was about it. I doubt you can really go much faster then that.
I guess you blew my theory out the window.
Old 07-28-2013, 09:21 PM
Camaro9969's Avatar
Incredible keep it up man those numbers are mind blowing! What year motor is it?
Now everyone is going to buy that turbo lol
Old 07-28-2013, 09:28 PM
offaxis's Avatar
Congrats on the killer pass !
Old 07-28-2013, 10:07 PM
35thsscamaro02's Avatar
Dear god! Bad ***!
Quick Reply: 76mm street Nova runs 8.39/163.75 mph!
